Troubleshooting BPDU Guard
The following procedures provide information to troubleshoot issues with Bridge Protocol Data Unit (BPDU) Guard.
For BPDU Guard to work on a port, the port must receive BPDU packets. Perform the following procedure to troubleshoot cases when the port does not receive packets.
  1. Enter Privileged EXEC mode:
    enable
  2. Show the BPDU Guard status for the port:
    show spanning-tree bpduguard {sub-port]][,...][slot/all][all]}
  3. Use the following command to verify that the port receives packets:
    show interfaces gigabitEthernet statistics verbose {sub-port]][,...][slot/all][all]}
  4. Verify that the remote port is sending packets:
    show spanning-tree {mstp|rstp} port role [{sub-port]][,...][slot/all][all]}]
    show spanning-tree {mstp|rstp} port statistics [{sub-port]][,...][slot/all][all]}]
Port 1/8 receives packets. The remote port is disabled and does not send BPDU packets.
The following example shows that BPDU Guard is enabled for port 1/8. The BPDU Guard administrative state for the port is enabled but the timer counter is 0.
Switch:1>enable
Switch:1#show spanning-tree bpduguard 1/8
                                   Bpdu Guard
Port      PORT         PORT                TIMER   BPDUGUARD    BPDUGUARD
NUM MLTID ADMIN_STATE  OPER_STATE TIMEOUT  COUNT   ADMIN_STATE  ORIGIN
1/8        Up           Up         120      0       Enabled     CONFIG
Switch:1#show interfaces gigabitEthernet statistics verbose 1/8
                                          Port Stats Interface Extended
PORT_NUM IN_UNICST  OUT_UNICST IN_MULTICST  OUT_MULTICST IN_BRDCST  OUT_BRDCST   IN_LSM   OUT_LSM
1/8    201          0          160062       60943        4          72           0         0
Switch:1#show spanning-tree mstp port role 1/8
                           CIST Port Roles and States
Port-Index  Port-Role    Port-State   PortSTPStatus  PortOperStatus
1/8       Disabled     Forwarding   Disabled       Disabled
Switch:1#show spanning-tree mstp port statistics 1/8
                           MSTP Cist Port Statistics
Port Number                        : 1/8
Cist Port Fwd Transitions          : 0
Cist Port Rx MST BPDUs Count       : 0
Cist Port Rx RST BPDUs Count       : 0
Cist Port Rx Config BPDUs Count    : 0
Cist Port Rx TCN BPDUs Count       : 0
Cist Port Tx MST BPDUs Count       : 0
Cist Port Tx RST BPDUs Count       : 0
Cist Port Tx Config BPDUs Count    : 0
Cist Port Tx TCN BPDUs Count       : 0
Cist Port Invalid MSTP BPDUs Rx    : 0
Cist Port Invalid RST BPDUs Rx     : 0
Cist Port Invalid Config BPDUs Rx  : 0
Cist Port Invalid TCN BPDUs Rx     : 0
Cist Port Proto Migr Count         : 0
Use the data in the following table to use the show spanning-tree bpduguard command.
Variable
Value
{slot/port[/sub-port][-slot/port[/sub-port]][,...][slot/all][all]}
Identifies the slot and port in one of the following formats:
  • a single slot and port (slot/port)
  • a range of slots and ports (slot/port-slot/port)
  • a series of slots and ports (slot/port,slot/port,slot/port)
  • all ports on the same slot (slot/all)
  • all ports on the switch (all)
Use the data in the following table to use the show interfaces gigabitEthernet statistics verbose command.
Variable
Value
Use the data in the following table to use the show spanning-tree command.
Variable
Value
{mstp|rstp}
Specifies the spanning tree protocol.
